Home Forums Products Rackmount Emote Fx Chain metering problem Reply To: Emote Fx Chain metering problem
#185215
formants
    I wanted to ask u homer if u are also experiencing no signal showing up in the “More Meters” view (front panel of the H9k) when making connection between in/outs  9-32 of a fx chain?
    …While my first FX chain’s metering is showing both in and output signals correctly in Emote, the metering is dead on the other 3 chains. Strange enough audio is going in and coming out of those 3 chains and processed as expected, despite the meters showing nothing.
    I only see signal flow from connections between i/o of the first 8 lets.
    thank u for your attention!
