Home Forums Products Rackmount Emote Fx Chain metering problem Reply To: Emote Fx Chain metering problem
#185327
    Hey formants,
    I think maybe some of the images did not show up on your more recent post.
    The FX Chain input/output meters will only display signal for channels 1-8. You have signal patched to FX Chain input 9, 11, 15, and 16. These inputs will not show signal on the FX Chain input meters.
    On the front panel, if you go to Meters > Assign, you can assign any group of I/O to be viewed and metered on the front panel. The Meter Bridge in Emote does not offer this same function.
    Let me know if that clears things up for you.
