Home › Forums › Products › Rackmount › Emote Fx Chain metering problem › Reply To: Emote Fx Chain metering problem
#185542
    Sorry, I’m not able to understand what the issue you are describing is with these images. Please email support@eventideaudio.com with a screen recording of the issue and we can troubleshoot the issue further there.
    In the video, please make sure you demonstrate the following:
    • Your audio routing from the DAW.
    • Which FX Chains you are using.
    • Which input/output blocks of the FX Chains you are using.
    • When the metering does work as expected and when it does not.
