Home › Forums › Products › Rackmount › H9000 + Emote + Ethernet Connection via cable direct to an iMac › Reply To: H9000 + Emote + Ethernet Connection via cable direct to an iMac
Hello, I just got a H9000R, downloaded all updates, and trying to connect to my mac Studio M1. For some reason emote does not find it, and when I go to network, it shows a “self-assigned IP” with a yellow dot. I really want to fix this issue. Used a CAt5, now a Cat8 cable and neither worked. I tried the wifi connection and it does not work either. I clicked the + sing in emote to manually add the IP and I used my Ethernet Self-Assigned IP and it shows the H9000, however when click “automatic connect’ shows and error msg. Please see attached picture.
What can you please help me?
