Home Forums Products Rackmount Routing template for MADI Reply To: Routing template for MADI
#194778
wilkinsi
    Ah, thanks.
    is there also the option to copy an algorithm from within one chain to another as appointed to having to drag it from the list of algorithms on the left column or import from an external drive? I may need the same algorithm with the same custom settings in two different fx chains for example.
