Home Forums Products Rackmount H9000(r) – disconnect on opening projects Reply To: H9000(r) – disconnect on opening projects
#195248
    Can you please provide a bit more information?
    When you open up the DAW and can’t connect to Emote, are you seeing the H9000 and you get an error message when you attempt to connect? Or is the H9000 not showing up at all?
