Home › Forums › Products › Rackmount › H9000 MADI 32 ch to MOTU 112D 56/64 ch. › Reply To: H9000 MADI 32 ch to MOTU 112D 56/64 ch.
May 4, 2026 at 7:32 am
#195299
The WC clocking should work fine for that setup. It’s not clear what the issue you are having is.
- If you’d like the H9000 to be clocked using WC, set the clock source to “Word Clock” and send a valid clock signal from an external device. It sounds like you’ve done this already but it’s not clear what the issue is from what you’ve described.
- You may also clock the H9000 via the expansion card by setting the clock source to “expansion card”. This should also work fine for your setup, and in this scenario you would not need the WC connection going to the H9000.
- If the clock source is valid, the Clock Rate parameter will display “locked” followed by the sample rate. When you change the sample rate from the source device, the H9000 clock rate should automatically follow. If there is a clocking issue, it will display “unlocked”.
