Home Forums Products Rackmount H8000FW and EVE/NET Remote Reply To: H8000FW and EVE/NET Remote
#197035
Fender17
    OK, I have managed to remove FW/ADAT Expansion Card, so I have reached the fuse. And it is probably blown or defective, it does not conduct.
    And now…. Manual says, that older H8000s (those with two mounting holes toroid transformer) cannot be used to power EVE/NET Remote. Mine is H8000FW, but it has that two mounting holes toroid…. So, may that be used to power EVE/NET or not?
    Should I use passive PoE 24 V to power EVE/NET, remove fuse in H8000FW and set jumper J2802 to OFF (ground lift)?
