Home › Forums › Products › Rackmount › removing adhesive feet from H9000 › Reply To: removing adhesive feet from H9000
August 23, 2026 at 1:17 pm
#198415
A sharp blade like an exacto knife should be able to pry them off easily.
Also, note the fans are on the side of the H9000. As long as there is adequate space on the sides/rear of the unit however it is mounted, you may not need a cooling fan underneath.
