Since rackmounting my H9000R, I no longer need the adhesive feet stuck to it’s underside. I intend to rackmount a cooling fan directly underneath. Unfortunately, they will not come off. Is there a safe way to remove them without damaging my H9000R?
A sharp blade like an exacto knife should be able to pry them off easily.
Also, note the fans are on the side of the H9000. As long as there is adequate space on the sides/rear of the unit however it is mounted, you may not need a cooling fan underneath.
