Home › Forums › Products › Rackmount › Routing template for MADI › Reply To: Routing template for MADI
August 28, 2026 at 8:45 am
#198861
How easy it is depends on the algorithm. It also may not be possible for every algorithn depending on how much CPU and memory is used.
Two big challenges for doing this are keeping the user interface useable and optimizing efficiency behing the scenes.
Also Eventide have a few tricks with some factory algorithms not available in VSIG. Finally, you’ll run out of algorithm ID’s or it will at least become very messy.
