Home › Forums › Products › Rackmount › (brickwall) limiter and use of multi-colours in emote › Reply To: (brickwall) limiter and use of multi-colours in emote
#204135
    Have you tried the Omnipressor algorithm? If you turn the function knob clockwise from 0, this will start at lower compression values and eventually get to an infinite ratio for limiting. The Omnipressor is very capable of a wide range of dynamics processing techniques, so I would suggest giving this a shot on the H9000.
    There are currently no settings to change the color of the text but this is a good request for the H9 algorithms. Thanks for the feedback.
