Can I route (by example) USB 1-2 to MADI 1-2 without using any FX chain?
Home Forums Products Rackmount Can I route (by example) USB 1-2 to MADI 1-2 without using any FX chain?
    • #115442
      Thierry Gauthier
        I plan to buy the H9000 w MADI expansion Card.  I have a question not resolve by reading the manual. Can I route (by example) USB 1-2 to MADI 1-2 without using any FX chain? I mean use it as a digital patchbay and keep all FX chain available?
        Tx
      • #152422
        jbamberg
          Yes, you can.  We call these "Direct IO" connections.  You can make a Direct IO connection from any input to any output.  You can also connect one input to multiple outputs.  However, you cannot mix multiple inputs to a single output.  We are planning to add this feature in a future software update.
        • #152423
          Thierry Gauthier
            This is great!  Tanks for the quick answer and good news (mix multiple inputs to a single output in a later software update)
