“Cannot Connect” in Routing Utility
Home Forums Products Rackmount “Cannot Connect” in Routing Utility
    • #107334
      I get the "cannot connect" message in the routing utility.  I'm de-selecting the checked "off-line" mode in order to connect. Sad
      I was originally able to connect without a hitch.  When I did, I created my own routing set up and saved it.  Since then, I loaded a different preset routing program in order to fix an issue with my blinking EXT light.  Now I want to go back to reload my saved program from the routing utility, but it won't allow me to go on line.
      Any solutions???
    • #120870
        Hard to say without being there, or without more information. Things to check:
        1) Communication Setup, especially baud rate if serial.
        2) Cables
        3) Serial/MIDI settings on the H8000.
        4) Does the yellow busy light on the H8000 flash every few seconds ?
