Can’t use HotSawz – can’t find “Restore Purchases”
Home › Forums › Products › Stompboxes › Can’t use HotSawz – can’t find “Restore Purchases”
    • #150602
        Sorry – not enough information. Apologies if this is obvious, but you will need to update all the units, not just the Max.
        Again, not clear where you searched to find ":Restore Purchases" – this is to be found on H9Control.
      • #150603
        bohan
          silver_mica wrote:
          I've got a Max and two Cores.  I've updated the Max and it has the HotSawz algorithm.   I've searche a bit to find the "Restore Purchases" button – but no luck.  Any help appreciated.
          Please go to the Settings screen and click "Sync algorithms with Eventide Sever" in H9 Control
          • #150606
            silver_mica
              Thanks @bohan – that worked.  What was throwing me off was the following
              H9 Control > Settings > Restore Purchases.
              Found here:
              https://www.eventideaudio.com/support/downloads/h9-maxout-program
              But, it seems this is outdated.
              bohan wrote:
              silver_mica wrote:
              I’ve got a Max and two Cores.  I’ve updated the Max and it has the HotSawz algorithm.   I’ve searche a bit to find the “Restore Purchases” button – but no luck.  Any help appreciated.
              Please go to the Settings screen and click “Sync algorithms with Eventide Sever” in H9 Control
          • #115061
            silver_mica
              I’ve got a Max and two Cores.  I’ve updated the Max and it has the HotSawz algorithm.   I’ve searche a bit to find the “Restore Purchases” button – but no luck.  Any help appreciated.   All pedals share same account, email, etc.
              David
