Certain patches produce loud distortion when loading
Home Forums Products Rackmount Certain patches produce loud distortion when loading
    • #110977
      Nickpancake
        I just purchased an eclipse and have noticed that when I load in patch 901TF 1:2 Multitap and patch 425 Waves  there is this terribly loud distortion like feedback that comes from the unit and I have to bypass it and power it down or it will just keep going. I have tried powering off and holding the program button to unload the patch on start up but it happens whenever I load up the patches. Also sometimes when I am going through patches there is loud clipping when I load a new program. It seems to be the ones that have very long delay and reverbs.
        I have my guitar going from a line 6 podxt into the inputs of the eclipse with standard guitar cables. I have the outputs of the eclipse going into my audio interface with guitar cables as well.  When I turn on the eclipse it says it has v 4.04. I think this is the most recent update? I'm not sure what I can do to fix this. . ? I hope there is a solution for this.
        Thank you.
      • #124568
          First, completely return the unit to factory defaults (UM p.53).
          If this does not fix it, you may have a hardware problem in the delay area, in which case you should return the unit to your dealer, or contact support@eventide.com
        • #124574
          Nickpancake
            Thanks I think that fixed it!
