Controlling Eclipse with Line 6 Helix
Home Forums Products Rackmount Controlling Eclipse with Line 6 Helix
    • #114076
      wilkinsi
        I know the Eventide stompboxes don’t need setting up to control Eclipse, but I now have the Helix, and am struggling to get Eclipse to respond correctly. I would like to do two things: 1) Use Helix to change PDM + and – on Eclipse, and 2) Use the Expression pedal on Helix to alter parameters on Eclipse. Which MIDI CC numbers should be used? Anything else I should set up?
      • #145978
          Don't know anything about Helix, so you must talk to line6 about that.
          To remotely control parameters on Eclipse you should read the "External Controllers" section starting on p.45 in the UM, as well as the sections on Parameters and Hot Keys. You ca, in general, use any CC you want (avoid CC #0).
