DSP 4000 Digital I/O failure
Home Forums Products Rackmount DSP 4000 Digital I/O failure
    • #112982
      Hi guys,
      When I open turn it on it says “Digital I/O Failure, please contact service”. Anyone knows what this is about?
      Many thanks
    • #141330
        It means that it has failed one of the startup self-tests on the digital I/O subsystem – most likely that one of the chips failed a readback test.
        If your unit is a "CE" type, with a removeable audio board, it might be worth giving the audio board connectors a splash of switch cleaner, and wiggling any socketed parts in the audio area. (At your own risk, of course).
        Otherwise, it will have to go for service.
        • #141345
          If your unit is a “CE” type, with a removeable audio board, it might be worth giving the audio board connectors a splash of switch cleaner, and wiggling any socketed parts in the audio area. (At your own risk, of course).
          Thanks for the reply Nick, I will try to open it up and give it a clean here and there without tampering with it too much and see if it works. I use the analog in/out and it works but I hope i wont have other problems with it in the future.
          Best,
          Cristi
