November 17, 2009 at 11:10 pm #106648
Italo,
is it possible to make a preset on the eclipse to emulate the tc2290, with both modulation AND ducking in a single delay algorithm?? Or is there a way to combine the ducking delay and – say – the vintage delay to make one delay preset with mod and duck?
I know the orville has a tc2290 preset, and I assume it's a bit too heavy for the eclipse to handle, but could you work on a lighter / easier version for us eclipse users?
Thanks
November 17, 2009 at 11:26 pm #119507
Right folder!
Thanks
My reply from the Harmonizer folder….
Hi kitsch
you can't get an exact 2290 copy on the eclipse as you have on
Orville/H76-8000 models. Infact these units allow dry signal dynamic
panning as in the TC unit.You could try using any modulated delay algorithm and patch its
delay mod rate, pan and level to FOLLOWER #1. This may lead to a
similar rsult, even though not so accurate as on the bigger brothers.Try #106 Chorusdelays and tweak a single delay; cut the other 3 delays levels down to -100dB.
Vintage delays is not well suited as it has a single delay level and an IMAGE parameter for both delays panning image.
best
I
November 18, 2009 at 12:02 am #119508
Italo,
I just tried to patch the level to follower#1 and the eclipse crashed. I just read that the new version 4.01 fixes this kind of problem, but I can access the download, as apparently my eclipse is not registered (I'm sure it was, as I already downloaded a few preview updates, including 4 beta and 4.0), and even worse, if I try to reregister it, I get an error message that says invalid serial number, but i'm sure it's the right one, it's in front of me! What can I do??
November 18, 2009 at 12:19 am #130638
Firstly, try it again a few times, and check for spelling, upper/lower case issues, etc.
If this does not work, you should contact support@eventide.com, being sure to give them the numbers you are using.
