June 27, 2018 at 11:15 am #114806
Hello!
I’m having some trouble getting the Eclipse to sync to Logic Pro X correctly.
The Eclipse is connected to my Focusrite Clarett 8pre via ADAT, and sending and receiving audio works great. I have the Eclipse set to “Clock: DigIn” and it reades the sample rate correctly.
I also have a MOTU Timepiece AV connected to my Mac Mini via USB, and one of the out ports is connected to the MIDI IN on the Eclipse. I’ve activated the MIDI Clock “Transmit to” option in Logic’s Project Synchronization Settings and chosen the correct out port on the MTP AV, and also chosen “Midiclock” as the Source in Setup->Tempo->Tap Src on the Eclipse.
I’ve loaded a delay program and set the t_delay to 1/8th, and since my project’s tempo is 130bpm, the delay time should end up at 231 ms. But when I hit play in Logic and switch to the “delay” setting in the Edit pages of the program on the Eclipse to check the delay time, it constantly jumps bewteen 10 000 ms and 231 ms!
I’ve searched for a while but can’t seem to find anyone who has encountered this problem before. I’ve tried the different options in the Logic MIDI Sync window, changing the “Mode” but it doesn’t seem to help.
Thankful for advice or answers!
Best regards,
John
June 27, 2018 at 3:07 pm #149571
I suspect that your MIDIclock has too much jitter for the Eclipse to handle. Do you have a non-computer MIDIclock source you could try ?
November 17, 2018 at 12:44 am #150615
Not sure if it is related, but I was told years ago that there was a bug, and there has been no OS update since then…
https://www.eventideaudio.com/community/forum/rackmount/tempo-midi-clock
