Eclipse Midi Map #3 not working.
Home Forums Products Rackmount Eclipse Midi Map #3 not working.
    • #115094
      stratocasius
        Hi there-
        Trying to get my Roland FC-300 to select from my SD Flash card using the MIDI MAP #3 option under Setup…but no luck.
        Seems to still only pull from the internal(1-100) patch roster and not from m card.
        Have it set as below…
        {PGMCHG#} PChg: 1 Prst:500
        Roland FC-300 still sending PC #1…but only loads internal patch #001.
        Set Roland from Omni to Channel 1 still no luck.
        Any ideas?
        TIA
      • #150770
          Sorry – works fine for me (of course).
          Make sure your PGMCHG screen looks like this (for preset 501):
          If it does, try a different card. It needs to be Compact Flash 2G or less (not SD), formatted as FAT or FAT32 (not exFAT).
