October 19, 2010 at 3:26 pm #107330
Just bought an Eclipse. Every time I power up I get the following sequence:
Loading Operating System…Internal RAM is new – clear and format it?
Yes – No
(If I select Yes it boots up and finishes on the screen..)
100 Mute-Series
If I select NO it finishes up but nothing works (display is dim and all buttons beep when pushed).
I didn't see anything about this in the User Manual and doesn't seem like something that should happen on every power-up.
October 19, 2010 at 3:31 pm #120867
You are correct – it should not do this. Sorry for the trouble.
It is almost certainly caused by a problem with the internal battery. If you are technical, you could open the unit (power off) and make sure that the battery is properly installed and has nothing caught between its contacts.
Or if otherwise, or if you understandably think that you should not have to do this, contact your dealer or support@eventide.com.
November 23, 2010 at 3:21 pm #121025
I am having the same problem with a Ebay purchased Eclipse… happened with the original 3.0 OS as well as after I upgraded to 4.01.
Is this a user replaceable item, is it a part available at typical places that sell batteries?
I am comfortable opening the thing up and checking connections and replacing a battery, any other precautions other than making sure the power cable is unplugged?
Thanks,
-jas
November 23, 2010 at 4:11 pm #132181
A capable user can change it himself – with the top off it is pretty self-evident. As you mention, the power cable must be unplugged first.
You will need a CR2330 or BR2330 battery, available from Amazon or eBay, as well as local suppliers. You will have to re-initialize the unit after changing the battery.
November 26, 2010 at 5:20 pm #132195
The battery change was easy to do and fixed my problem.
The hardest part was driving around town finding the Cr2330… not even Radio Shack stocked it. Finally located it at a dedicated battery store (Battery's Plus or something of that nature).
Thanks for the help… glad to have my settings 'stick' now!
-jas
November 30, 2010 at 1:57 pm #132211
Just to throw another option out there, Digikey seems to always have large stock on hand.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P187-ND
DK p/n P187-ND
