January 18, 2011 at 6:38 pm #107574
dsmbennett
MemberHi
I am having trouble in making a back-up of all the user defined presets i have programmed into my Eclipse so I have an easy way to restore all my user defined presets in an emergency.
I read through the manual (and messed about with my Eclipse) but cant seem to find a clear way to make this back-up?
Any ideas?
Cheers,
Dave
January 18, 2011 at 6:41 pm #121430
ModeratorEventide StaffI would think that the best way would be to use the Bulk Copy utility (UM p.52) to copy them to a CF card. You could then save them to a computer for extra protection.
January 18, 2011 at 7:34 pm #121431
dsmbennett
MemberHi Nick,
Yes i did try this, but i can't seem to select the card as the destination. It always seems to copy my presets into the internal memory?
I am probably missing something very simple here, but admit I cant figure it out :o)
Dave
January 18, 2011 at 7:52 pm #132622
ModeratorEventide StaffYou may well be more familiar with this than I – if so I apologize. But, did you set the DEST_FRM parameter to 500 or above ?
January 18, 2011 at 9:04 pm #132625
dsmbennett
MemberHmmmm …. as it was a while ago I believe I did. Will this just copy presets onto the internal memory??
January 18, 2011 at 9:40 pm #132626
ModeratorEventide Staff500 or above should give you the card.
January 18, 2011 at 10:20 pm #132627
dsmbennett
MemberAh… didn't know that :o(
Said i was missing something simple! It didn't point this out in the manual for the Eclipse but will try it on my next gig in that case.
Many thanks again Nick :o)
Dave
January 18, 2011 at 10:49 pm #132629
ModeratorEventide StaffSee UM p.28 for information on Programs and numbers.
I tried it (rather than just relying on the UM) and it works fine. Phew !
January 18, 2011 at 11:23 pm #132630
dsmbennett
MemberAh, yes it is on page 28 as you say :o) (Told you i was missing something simple..doh!)
Many thanks for the help, and I will take my memory card to next gig and make the back up.
Thanks again,
Dave
May 22, 2011 at 7:53 pm #122179
wynsmth
MemberWow, that's really well hidden!! OK, no how do you reinstall all your saved programs for a memory card. I can't find anything anywhere in the manual that even remotely comes close to answering this.
May 23, 2011 at 4:00 pm #122182
ModeratorEventide Staffwynsmth:
Not quite sure what you mean. If you are trying to copy saved programs from a card back to the Eclipse, you would use the Bulk Copy utility described above.
