November 7, 2018 at 8:11 pm #115041
Klause893
MemberI am curious how to the rotary sounds of the Eclipse stack up to the Neo Vent 2 pedal. There are comparisons of the H9 and the Neo, sadly with the H9 falling very short. The fast rotary sounds weren’t terrible on the H9 (still needed work though), but the slow settings left much to be desired. I’d say your average chorus or phaser is beter suited for getting slow, Gilmourish leslie tones than what I heard on the H9.
Being in a much more powerful rack format can the Eclipse get closer to the Vent? Or does the Eclipse use the exact same algo which will yield the same result? I can’t seem to find any demos of the Eclipse with slow rotary sounds on a guitar, so any info you can give is much appreciated.
November 11, 2018 at 7:18 pm #150567
ModeratorEventide StaffNote that the rotary is the ONLY thing the Neo Vent 2 does. The Eclipse or H9 also do 50 other things.
If rotary is the ONLY thing you want from a pedal, you might want to spend the $600 on the Neo.
If you are more open-minded, an H9 or an Eclipse might be a more useful tool.
November 11, 2018 at 9:36 pm #150570
Klause893
Membernickrose wrote:Note that the rotary is the ONLY thing the Neo Vent 2 does. The Eclipse or H9 also do 50 other things.
It’s not about being open minded, the Eclipse is a big price jump up from the H9 and not to mention everything else involved to take full advantage of it like rewiring my rig up with a stereo line mixer which is going to be even more money. For the price I expect it to be a go-to piece of gear for many things, not just delays and reverbs.
Show More...Show Less...Since the rotary algo on the H9 is well known for being subpar (esp the slow setting), I just was needing to know if I dropped all this cash on the Eclipse is it going to get me closer to that tone and fidelity than a H9? Folks have been asking for an update on that algo for a while now, as well as other presets from the modfactor series. Seeing something like the HotSawz algorithm get priority over reworking the less than desirable modfactor algo’s should be frustrating to Eventide users.
Not trying to bash, the Eclipse seems to be the right thing for my needs but these are fair concerns to have prior to purchasing I think.
