- This topic has 2 replies, 2 voices, and was last updated 3 years, 3 months ago by
cyberpunx.
January 4, 2023 at 2:51 pm #168233
Hi!
Which CC-numbers/controllers does The Eclipse support for modulatiing its parameters, via EXT:s, from for instance a DAW (in my case Cubase 10)?The only one for some odd reason that i have managed so far to get to work is CC1, the mod-wheel, have also tried CC4, foot-controller and CC7, Volume without any luck, that is the choosen parameters values does not change. In my case i tried with a reverbs decay-time.
From the manual, the little that is written about this, i get the impression that you can choose any CC-number you like, but that does not seem to be the case. And since i cant find any midi-implementation chart for the Eclipse, have there ever been anyone?, i have to reach out to you guys here for some guidance 😀
thanks very much in advance for the forthcoming help 😀
January 4, 2023 at 5:10 pm #168248
I’m not sure if there was ever a traditional MIDI implementation chart, but all of the information can be found on page 45 of the user manual: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/EclipseUserManual.pdf
The standard MIDI messages are already mapped by default (mod wheel = CC1, breath = CC2, etc.) but you can map any CC by selecting “MIDI single” and then choosing the CC number using the “CNTRL” parameter.
For example, I just set ext1 to use MIDI single > CC #43 and now any parameter that is controlled by ext1 will respond to MIDI CC #43.
Let me know if you are able to get it working.
January 5, 2023 at 2:09 pm #168281
to tbskoglund:
yes of course i got it working, well after three sessions in as many days but what the heck i got it running. it was mainly a logical fault in my thinking of how to use the CC-mess/controllers in my DAW (cubase). Once i got in the right frame of minnd regarding that so to speak, it got the ball rolling.
it was just a matter of using the cc-messages in the right way set with the right values you can say 😀 😀 😀
thanks a lot for your help 😀
