Effect only on one side
Home › Forums › Products › Rackmount › Effect only on one side
Viewing 3 reply threads
    • #107855
      I just got a used Eclipse & I can only get the effected signal on one side & totally dry on the other. I am in a stereo in/stereo out effect loop of a Zentera combo amp. I can make the sides reverse by switching the cables & outputs so it's not the amp or the cables. Is this normal, is there some setting I am overlooking or do I have a defective unit? Thanks,
    • #122068
        If you've just got it, you would be well advised to return it to factory defaults (see UM). This will fix any inappropriate settings.
      • #122071
        Thanks, I tired that yesterday & it cleared things up but I would like to know where that setting is for future reference or was it just a glitch in the system. Thanks
      • #133366
          No glitches in this system !!
          Could have been one of two things that I can think of:
          1) Wet/dry set to 100% dry on one channel
          2) If V4.0 or later, could be output in mono mode (UM p.22)
