Emote and Apple Logic – AU Failed Validation
Home Forums Products Rackmount Emote and Apple Logic – AU Failed Validation
Viewing 3 reply threads
    • #115201
      Racerx1492
        Running Logic Pro X 10.4.4
        Mac OS 10.14.3
        On launch of Logic Pro X, there is an incompatible Audio Unit dialog box that pops up.  If you start that plug-in manager Emote shows up as “failed validation”.
      • #151275
        Racerx1492
          Using Emote 1.0.0.47
          Mac OS 10.14.3
        • #151350
          jfirlik
            We've been able to reproduce an AU validation issue on Mojave.  We'll look into it, thanks for the report…
          • #151351
            jfirlik
              Actually, the problem we were seeing was using an earlier version of Emote.  The 1.0.0[47] version fixed the validation issue, is it possible that you still have a previous version installed?  In the standalone version, hovering your mouse over the Eventide logo in the bottom right should display the actual version number.
              • #151353
                Racerx1492
                  I had 1.0.0(47) installed when it failed. I did have a previous version prior to that.  It’s possible that the AU plugins didn’t upgrade between versions.
                  I can’t check empircally as I just upgraded Emote to the public beta 1.1.4(0)  It validates fine in this new version of Emote.
