Eventide DSP 4000B+ Analog I/O code 1000 message
Home Forums Products Rackmount Eventide DSP 4000B+ Analog I/O code 1000 message
    • #116315
      Hello
      I was wondering if someone could help with this problem.
      When i turn the unit on i get this message and the sound doesnt pass troug. I tried the factory reset ( the one with pressing the 8 key) and it doesnt solve the problem.
      I hope someone can tell me what is wrong with it.
    • #156947
        It means that it gets the wrong value on reading back from the ADC or DAC – a hardware problem.
        If you are handy, you could try wiggling all socketed parts in the audio section, otherwise it has to go for service.
      • #157014
        I will try that, thank you so much!
