Eventide H9000 Loud Fan
Home Forums Products Rackmount Eventide H9000 Loud Fan
Viewing 3 reply threads
    • #150430
      jbamberg
        macgee wrote:
        Hi there I finally received my H9000 and was setting it up this evening however am finding that continuously, the fans are quite loud. Actually as loud as a MacBook Pro when the fans spin up quite fast. Is this normal behaviour or should the H9000 be quiet in operation? Thanks
        The fan should be almost inaudible unless you are in a quiet room (definitely quieter than a MacBook Pro when its fans spin up).  It runs continuously at a constant speed.  We chose this particular fan for its quietness.
        Since our QC procedure currently doesn't check how loud the fan is, and our production area has some ambient noise, it's possible that your H9000 has a fan which is out of spec and needs to be replaced.  If you contact us via email to support@eventide.com, we can arrange for this.  I apologize – this isn't something we anticipated.
      • #115027
        macgee
          Hi there
          Thanks
        • #151141
          DeWalta
            how did this story end? was the unit replaced or are the fans really as loud as a mac book pro?
          • #151143
            macgee
              Eventide arranged for a check by the local distributor. To make it easier I drove over to them, they looked at the machine and didn’t see anything wrong so they just dropped the voltage to the fan to about 7.5v from 12v if I remember correctly whicgh made it quite a bit softer and then put rubbers between the fan on the stands…like a rubber washer. Anyways I think just slowing the fan made the biggest difference and I’m happy now
