Expression pedals
Home Forums Products Rackmount Expression pedals
Viewing 3 reply threads
    • #107057
      I watched the Eclipse demo videos and saw that a few of presets the presenter used a volume pedal type expression pedal.
      Can this be used to control delay times or delay feedbacks or reverb lenghts and such?
      Can they be used to control Rotary/Leslie speeds or would it be best to get an on/off for a fast/slow sort of action?
      What expression pedals work best with the Eclipse?
    • #120351
      Hi
      you can control practically all parameters in Eclipse, using pedals, footswitches and MIDI CCs.
      For the leslie a switch is a more natural controller.
      You can use common passive volume pedals with IN and OUT 1/4" jack connectors and a stereo cable connected to a stereo 1/4" jack connector (Eventide) and two mono ones to be plugged into the pedal.
      best
      I
    • #120356
      Thank you..
      My Midi controller is a simple Mesa Boogie Abacus which is only good for program change.
      Brian
    • #124097
      How do you assign the expression pedal to an effect parameter in Eclipse?
