Foot controller and expresion pedal for the H9000
Home › Forums › Products › Rackmount › Foot controller and expresion pedal for the H9000
    • #115471
      maxenbit
        Hi, i am very happy because (after a deep research) I have decided to buy an H9000 and now I am looking for the best option for foot controllers and expression pedals.
        I did some research, and these are the options I have found:
        Option 1 (Foot and Exp) In the Peter Freeman youtube video posted on your H9000 page and he uses de FAMC Liquid pro+24+
        https://www.famcmusic.com/product/liquid-foot-24-pro-plus/
        https://www.famcmusic.com/product/lf-plus-12-plus/ https://www.famcmusic.com/product/expression-pedal/
        Option 2 (Foot & Exp)
        https://nektartech.com/pacer-midi-daw-footswitch-controller/
        https://nektartech.com/np-1_np-2_nx-p/ (Nx-P)
        Option 3 (Exp – tested by Eventide Staff in another thread)
        Roland EV-5 Expression Pedal
        Option 1 & 2 works fine with the H9000?. Any other recommendation?
        Thanks in advance!! Xavier
      • #152533
        The RJM GT/16 is an absolutely stellar option:  http://www.rjmmusic.com/mastermind-gt-16/
        It is incredibly flexible and configurable.  Having LCD screens above each button is a BIG plus.  The editor software (Windows or Mac) is laid out incredibly intelligently.
        Also it looks super classy and is very, very well built.
        On top of that, Ron will respond to your questions personally and provide great support.
        it works very well with the expression pedals from Mission engineering.  I recommend the SP1-RJM:
        https://missionengineering.com/shop-2/products/expression/specific-use-exp/sp1-rjm/
        Note that most mission pedals are wired in an opposite polarity to the RJM default and require some simple soldering to reconfigure (the model I recommended comes “correct” out of the box).
        I’ll attach a pic of my pedal board.
        You cannot go wrong with this combination!
      • #152553
        donrwatters
          I use a Behringer FCB1010 connected via MIDI with an additional Mission Engineering Aero EP-25 Pro, connected to the Pedal 1 Input. It all works great. I use MIDI learn a lot in Emote. Every preset is different, in terms of what I need to alter. So, it just depends on what I’m trying to control. I use the H9000 to mimic the effects in the H9’s that I own, so it’s like trying to control 16 H9’s. Most times I’m only controlling 4 different algorithms, but on occasion things get out of hand and I have all 16 algo’s running and I need to control sweeps or bandpass filters across all algo’s, or even input gain for each chain. This setup works well.
          More than what you asked for, but I’m including other info, in case others come across this thread in the future.
        • #152562
          maxenbit
            Thanks for your help!!!
            I asked some questions at the RJM forum and you are right tthe RJM GT/XX is a stelar option for the H9K and also for the other devices in the midi trhu chain!
            https://www.rjmmusic.com/forum/index.php?threads/gt-10-16-22-button-%C3%A1rea-split-to-control-two-or-more-devices-w-o-changing-the-device.3877/#post-19438
            Thanks again!!!
