Fx block setup
Home Forums Products Rackmount Fx block setup
Viewing 3 reply threads
    • #109296
      jac
      I was wondering if it matters what block fx are saved in! Example, generally you would put chorus & delay stomp boxes before reverb! So, lets say delay in block A reverb in block B! Any, thoughts?
    • #124017
      What you describe applies to a series routing (see UM p.38). It would be different for the other routing types.
    • #124018
      jac
      Thx, I've always run the two blocks in parallel! But always seemed to me that block b fx was not mixing with a they way I wanted. So, I put the routing in series way cooler!!!! it only took me several years to figure it out! I just don't really want to flip the block around!
    • #135019
      wilkinsi
      You could always save it to another program number. Not to sound like a rep, but you're only limited by your imagination and willingness to experiment. Same applies to external routing. All the outputs are permanently active.
