H8000 FireWire Setup issue
Home Forums Products Rackmount H8000 FireWire Setup issue
    • #109247
      Jack Weaver
        false
        18 pt
        18 pt
        0
        0
        false
        false
        false
        New here, Got a new H8000FW today.
        Trying to install it via FireWire .
        OSX  10.6.8
        Hooked up FW cable
        between H8000 & computer.
        D/L’ed Eventide Dice and
        installed it (along with EventideRoutingUtility). Restarted computer.
        Don’t see the H8000 icon in System Preferences/Other pane. Opened up Eventide
        Dice via ‘Applications’ and the Global Settings within Dice see the unit and I
        was able to set proper sample rate and internal sync source. These also look
        fine on the lights on the unit itself. The unit display also shows ‘FIREWIRE 1’
        as (OK).
        Clicked on ‘Sound’
        within the System Preferences and was able to choose ‘Eventide Dice’ as output
        – there was no ‘Eventide H8000’ as a choice on which to click. Not able to get
        alert sounds through ‘Eventide Dice’ out of my system.
        Logic Pro 9.1.8 does
        indeed see ‘Eventide Dice’ as a device driver.  The manual’s instructions say,
        ‘You
        will now be prompted to restart your computer for the new setting to take
        effect.’ But I believe that all you have to do these days is click ‘Apply’ for
        this to occur.
        I haven’t yet bothered to setup the Aggregate Device
        since I don’t have the proscribed driver showing in the Apple System Preference
        pane.
        What have I done wrong? Perhaps you can set me straight.
        Thanks,
        Jack
      • #123957
          It sound like you have the drivers installed, so it's unclear why you can't make the Aggregate Device.
          Presumably Eventide Dice is the same as Eventide H8000. The names seem to change with every new version of the driver – don't know why,
          You'll have to make routing changes to get FireWire sound through the unit – are you sure this is set up OK ?
          It's always a mystery to me that sometimes you have to restart and sometimes you don't.
