H8000 word clock problem
Home Forums Products Rackmount H8000 word clock problem
    • #114547
      audiomichael
        I just bought an H8000. It’s a glorious sounding box. But, I’m super confused with the word clock. I’m hoping I can get some help with it.
        I have Analog XLR 1-2 routing to Processor A: 1-2. Digital AES 11-12 (via Dsub) routing to Processor B:3-4.
        So basically I can have 2 independent processors / fx. 1-2 through analog, 3-4 through AES.
        I read that word clock will not be received through AES-EBU 1-2, so I’m using the DSub 11-12 input. Still it shows that my AES 11/12 is “slipping”. I’ve never had a problem with clock digital on my Eclipse that this H8000 replaced. I don’t have dedicated word clock to the word clock in. It should be receiving word clock through the AES signal.
        Thanks in advance for any advice.
      • #148129
          I'm going to assume that when you say "word clock", you acutally mean sample rate. (Word clock is a specific signal that does not connect to AES).
          Your problem here is that you have the sync source ("Source:") set to internal. Your AES signal is coming from something of a similar sample rate, which is why it is slipping rather than showing unlocked.
          You have two options:
          1) (Probably best) Set "Source": to lock to AES11/12. This means that the whole H8000 will be running at the exact same sample rate as whatever is feeding it. It should then show AES11/12 as locked.
          2) If you really need the H8000 to be running on internal sync (can't think why) you should connect your AES signal to AES1/2 and then enable sample rate conversion.
        • #148136
          audiomichael
            Thanks!  I missed that you have to set the sample rate source for both DSP sections.
            I got everything working.  Strangely, I have to use AES 13-14, because the H8000 would not let me select 11-12 as a Sample Rate source.  But It’s working, so I’m not complaning.  Whew!  That is a complicated and deep routing/setup structure 🙂
            Thanks for the help!!!
