H8000FW ISSUE
Home Forums Products Rackmount H8000FW ISSUE
Viewing 5 reply threads
    • #108540
      Dario
        Hi, I have an issue with my H8000FW,
        when I turn on the unit, after all the initial procedures and testings (everything seems to be ok) the screen display says :
        " Problems found during startup  See Setup/Info for details, Press any key to continue".
        after pressing a key, the H8000 load my previous preset.
        Then, when I go to SETUP —-> INFO page a problem is reported, it says :
         " 1) Problem in Internal Ram bad checksum "
        what can I do?
        let me know,
        thanks
      • #123244
          This means that the internal program and data storage memory has become slightly corrupted. It's probably not a problem. You should read the section titled "Fixing Internal Memory Problems" (UM p.146).
        • #123245
          Dario
            Ok, thanks for the suggestion,
            I will perform the operation described on the page 146 of the UM and I'll see wht will happen..
            a question:
            my unit comes with the 5.3 OS, if I update it to the latest 5.6b OS could be an alternative "path" to fix the problem?
          • #134350
              You might want to seriously consider updating to a later version, but it won't fix this particular issue.
            • #134351
              Dario
                I've performed the fixing internal memory operation, now everything seems to be ok…does this problem will appear again in the future?
              • #134352
                  If it occurs frequently, it would be a sign of either too many cosmic rays, or more likely a need for a new battery.
                  If the battery has to be changed more than every 5 or 10 years, it would be a sign of a hardware fault.
                  Most likely, none of the above.
