March 12, 2015 at 9:15 pm #112414
Ever since last night when I turned on the Eventide H8000FW I now get the following message:
Problems found during startup
See SETUP/info for details
Press any key to continue.
Is there a simple fix or does the unit need to be sent back to Eventide for servicing. I live in New Zealand.
March 13, 2015 at 2:15 pm #127625
I think you should do what it tells you …. then come back with the info.
March 13, 2015 at 6:29 pm #138531
When I do that all is per usual until the next time I power up the machine. Then the same message appears. I am wondering if the battery needs replacing or something. It has been in there since 2007.
March 13, 2015 at 6:53 pm #138532
This message only appears at power up.
It clearly says "See SETUP/info for details."
Have you done this, and if so, what did it say ? If not, uh, do it.
March 14, 2015 at 12:13 am #138538
Sorry I was pressing the SETUP key and then it went straight to the program. I have now gone to the info page in the SETUP and it says there is a bad checksum in internal memory. The following message shows:
1) Problem in Internal Memory bad checksum
March 14, 2015 at 12:20 am #138539
I have sorted the problem. I had to go to service in the SETUP area and press fix internal. It powers up fine now.
