Home › Forums › Products › Stompboxes › H90 General Modulation Algorithm Questions
- This topic has 14 replies, 5 voices, and was last updated 7 months, 1 week ago by
brock.
July 1, 2025 at 8:53 pm #190787
Hi, some general questions for Eventide staff regarding H90 modulation algorithms. I love the algorithms but the number of options are intimidating. If there is already a video that explains most of this from the Modfactor days, please post a link.
1) Does the ADSR modulation source work well for some effect types when playing guitar? Or, is that modulation source primarily included for synth/key players?
2) For the 4 chorus types: Liquid, Organic, Shimmer, Classic, which one is intended to be closest to 80’s rack chorus?
3) Do all intensity/mix parameters go from 0-100% or are there are subset that always have some % of effect mixed in? I think Instant Phaser and Flanger are effected signal only at 0% setting, but are those the only exceptions correct?
4) For phaser/flanger, the manual says intensity is ‘effect level’. Is this still wet/dry mix?
4) When ‘manual’ is set as the modulation source for both the primary and secondary modulation, I know speed value doesn’t matter on the primary oscillator. Depth still matters, correct? What about on the secondary oscillator?
5) Are there any particular tricks or hacks for setting the primary and secondary modulation sources? There are so many combinations, I am wondering if I am missing a particularly interesting combination (whether in general or on specific algorithms).
July 2, 2025 at 11:38 am #190804
There’s a lot to unpack here. Not a staff member, but maybe I can help give Eventide a little head start. I’ve done enough forum research on these same topics to link a few of the results below.
- ADSR will work with guitar, sometimes better due to the sharp attack. It has a fixed shape of short durations for each stage. It does need fine-tuning of Sensitivity for the best results. Try it on some type of deep effect to get a feel for it.
- IMO, the 5th: TriceraChorus. But also see the descriptions in the ‘link-of-links’ below.
- The Instant rack FX do have unique Mix ranges, but also see discussions in the ‘link-of-links’ below.
- Specific answers found in the ‘link-of-links’ below.
The ‘other’ 4). and 5). – These almost need their own dedicated reply, because you’re right: there are many combinations to cover. I’ll try to expand with more specifics later on.
- A good place to start is to set Depth & Depth Mod to median values. If Speed is set fairly low, then dial the Mod Rate multiplier higher. Speed fast, Mod Rate low. It’ll be easier to hear the effects of each on the modulation, and tweak it from there.
- It also helps to start out with a predictable Shape & Mod Source (Sine, Triangle). One method I use is to map the [P] HotKnob to Shape, then the [A] HotKnob to Mod Source. Makes short work of trying out all of the possible combinations.
- Always map the Manual parameter to an EXP pedal (if possible), whether it’s in current use or not. That way, it’s always active when Manual is selected for Shape and/or Mod Source. In some effects, it’s better to ‘reverse-map’ the Manual parameter from 100-0.
July 2, 2025 at 12:36 pm #190806
… There are so many combinations, I am wondering if I am missing a particularly interesting combination (whether in general or on specific algorithms)…
A couple more:
The Brake / Speed Performance parameter in combination with primary & secondary modulation. SLOW drops it to 1/8 of the value shown as ‘ Slow x’. Its position is saved as part of the Preset. And it’s really useful with two Modulation effects – Series or Parallel – each having their own Fast/Slow toggle.
Since the secondary modulations are truly amplitude & frequency modulations, very high values in Speed, Speed Mod, Mod Rate get you into ringmod- & synth-type effects. Use the Depth / Depth Mod controls to ‘tune’ & modify the results. That applies in any similarly configured modulation type.
More nuanced effects with Speed, Speed Mod, Mod Rate at the lower ends, especially adding in Brake / Speed. Use this tactic for ‘motionless’ modulations, pushing the LFO cycling well into the background.
July 2, 2025 at 3:28 pm #190812
Here’s a great thread going into depth with the Chorus modes from the engineer that designed it: https://www.eventideaudio.com/forums/topic/modfactor-fx-types-definitions
As Brock mentioned, I also recommend the newer TriceraChorus algorithm for what you’re after. The effect can give you analog-style choruses or Tri-stereo chorus like the popular rack units from that era. The factory presets are fantastic.
July 3, 2025 at 2:01 am #190821
Brock & Joe, thank you very much for the replies. I’ll pore through your info and the links, appreciate the help! TriceraChorus indeed sounds phenomenally good. The multiple chorus lines in TriceraChorus really ‘smooth out’ the warbles and make it incredibly lush.
I hadn’t considered running 2 different modulation effects in parallel or series. There goes my 4th of July weekend 🙂 Only 250 years to go from dumping tea in a harbor to whining about too many algorithm options!! We are indeed blessed.
July 3, 2025 at 6:19 am #190823
… I hadn’t considered running 2 different modulation effects in parallel or series. There goes my 4th of July weekend 🙂…
Not sure if this is going to make or break those BBQ plans, but I’ll provide the propane tank.
July 3, 2025 at 11:38 am #190825
Thanks for the very helpful questions and answers guys!
May I hop in with a pedestrian question?
I’ve noticed that many of the ModFactor factory presets have the secondary LFO depth and speed parameters set to “1”. Some, of course, set these to “0”.
While the difference seems negligible, I have to believe it’s not. I have to believe there is more than meets the eye there and, thus, that “1” makes all the difference for some reason.
Any thoughts on that? Thanks!
July 12, 2025 at 1:24 am #190909
Quick update: I went ‘all-in’ and created an entirely new User List dedicated to only modulation effects. Of course, I named it ModFactor. I then proceeded to save a representative preset from each modulation algorithm in the ‘preset A’ slot of every 7th program in the ‘ModFactor’ user list. All preset B slots were left in the ‘thru’ utility algorithm so I could focus on modulation only. The intervening 6 program slots were left open so I could save interesting combinations of primary and secondary modulation whenever I stumbled across them. Or, the open programs may be used for series/parallel modulation in A and B preset slots – once I venture that far.
Just thought I would share in case there are other H90 users who did not grow up on the ModFactor, H9, or another preceding Eventide product. I’ve found this to be a nice way to keep sounds simple and just tweak & listen without trying to rely on a relatively weak theoretical understanding of what’s happening under the hood.
July 12, 2025 at 3:32 am #190910
That’s a cool way to do it. I’ve recently been doing something similar. I have a List called “All Algos In Order” where the first 68 Programs each contain just Preset A of a single algorithm, in the order in which they are listed in the manual. Preset B is “Thru”. I am currently about half way through, trying to make a nice subtle preset that works with my guitar, with simple routing. This is similar to how I used to do things on the H9. Then if I want to play around, change the routing, add effect B etc., I have a different List that I can copy and paste to of “current” sounds I am actually using in my work. The “All Algos In Order” List gives me a perfect starting place for every algorithm.
It’s all fairly easy to do with the H90 Control app on my PC, although I do wish they’d make a phone Bluetooth version so I didn’t have to deal with the USB ground loop hum when the H90’s plugged into the computer. I also wish you could Drag & Drop Programs around in a List. The only problem with my current scheme is that when they add a new algorithm, I’m going to have to shift everything around somehow to keep the correct order, and without Drag & Drop support, it might take forever. 😉
Anyway, interesting to hear how others are doing their patch management!
July 15, 2025 at 9:53 am #190926
… I have a List called “All Algos In Order” where the first 68 Programs each contain just Preset A of a single algorithm, in the order in which they are listed in the manual. Preset B is “Thru”…
I did the same for a PatchStorage upload called Algo Programmer’s Toolkit. I stopped updating it online at 64, as ET introduced their own defaults for each algorithm. I do prefer using my own for starting from scratch, though. ‘Cleaner’ with no hidden mappings, and organized in its own List, much like your own.
… I have a different List that I can copy and paste to of “current” sounds I am actually using in my work…
I believe it was @apalazzolo that I first saw use this trick. He explained the process much better than I will here.
Basically, your ‘Current Destination’ List is loaded into the H90. Move from the Edit tab to Programs tab in H90 Control, and use your ‘All Algos In Order’ within the search box. Then (on the left), progress though each INIT Program to build the new ‘Current Destination’ List – from the ‘All Algos In Order’ Programs on the right side.
Just remember to hit the Save icon (lower-left of ‘Current Destination’ box) each time you auto-load the next Program. Beats shifting Lists and a bunch of Copy / Paste operations.
… I also wish you could Drag & Drop Programs around in a List.
I’ve seen enough requests & replies to think that improvements are up there in the priority list.
Mine is a mess. I am a compulsive List-aholic. It’s both a blessing & a curse to have “unlimited” Program Lists.
I do have 100% finalized Lists, categorized for covers, general live use, etc. But then there are all 99 Program ‘concept’ Lists, where I take an algorithm or pair as far as I can possibly go, or try to emulate some vintage unit. PatchStorage upload Lists (mainly so I don’t repeat myself). Partial ‘raw Idea’ Lists. Experimental. A few for just for granular-esque …
Appropriately re-named Lists become essential. Now I’m at the point of having to scroll quite a bit just to find what I’m looking for. This would be a great place to mention performing the occasional full backup in H90 Control.
July 15, 2025 at 10:46 am #190927
Thanks Brock, I always appreciate your posts on here!
Good to hear Eventide have their own basic starting patches for each algo now too, I just checked them out in the Preset Library in H90 Control, I hadn’t realised that before.
The trick you mention is great! I’ll give it a go. Will be easier to arrange things for me, if they add a new algorithm before they add Drag & Drop, but hopefully, like you say, that will be implemented at some stage.
I’ll back up my H90 now… 🙂
August 2, 2025 at 2:49 pm #191349
Ok, a very specific question about the Phaser algorithm and the primary/secondary modulation. If I have envelope selected as the primary modulation source, the speed knob becomes ‘sensitivity’.
Does the secondary ‘speed mod’ do anything? It’s not modulating the sensitivity, is it??
August 2, 2025 at 3:58 pm #191353
In that case, Speed Mod doesn’t appear to do anything (Envelope as primary). Depth Mod & Mod Rate add more of a parallel modulation to the primary ENV, rather than directly modulating its Sensitivity. Not sure exactly how it’s all routed internally, but that’s what I hear. The same can be said for primary ENV + secondary ENV. Depth Mod and Speed Mod are inactive. Not the most useful combination, but it doesn’t stop me from trying.
These modulations all add up (or multiply together). In any Shape+Mod Source scenario, balancing Depth & Depth Mod levels is key. For many combinations, also Speed & Speed Mod mixing.
The various ENV / ADSR combinations still tend to stall me in my tracks. My rough rule of thumb: primary Envelope + secondary waveforms, for fixed rate modulation alongside an envelope. Primary waveforms + secondary Envelope, for ramping the rates. I revisit Primary Envelope/ADSR + secondary Envelope/ADSR on rare occasions. Usually ending up with Manual substituting for one of them.
August 3, 2025 at 2:59 am #191356
Cool, sounds like (pun intended) we are hearing the same thing.
I like to think of depth mod, speed mod, and mod rate as adding ‘glitchiness/wackiness/saucy-ness’ to what would be an otherwise well behaving primary modulation source.
This is why I started the thread…I’ve been driving myself nuts trying to find ‘unique’ combinations.
Agreed with this. Using Env/ADSR on either the primary or secondary modulation makes sense. It’s hard to figure out what’s happening when they are applied to both.
I dare not ponder what happens when both primary and secondary modulation are set to manual. Eventide Staff: please save our sanity and explain 🙂
August 3, 2025 at 12:51 pm #191360
… I dare not ponder what happens when both primary and secondary modulation are set to manual. Eventide Staff: please save our sanity and explain 🙂
You’ve crossed the line where the laws of all known physics break down.
I had to revisit … my Manual go-to tactic has become mapping the Manual parameter in opposite directions, with multiple instances or two similar algorithms. Vocal-like formants, with the focus on crossing frequencies.
So I threw together a test Program (attached). #1 Manual Shape + #2 Manual Mod Source. I bypassed a 2nd identical Phaser instance. Enabling it in Series pushes the boundaries. EXP1 is mapped to Manual Mod. I saved it at mid-throw, as ‘manually’ adjusting Manual Mod & Depth Mod also produces audible results. AUX / HotSwitches select Phaser types (intense Feedback Type as HS2 default).
- Logically, Speed, Speed Mod & Mod Rate don’t apply.
- Depth & Depth Mod do interact.
- Control Depth Mod with the (P) HotKnob, or an EXP2 pedal.
- Control the primary Depths with (A) / (B) HotKnobs.
- With Depth = 99, increasing Depth Mod ‘hollows out’ the range of Manual control.
This mellowing seems counterintuitive (adding more modulation). Considering the source (Phaser), I’ll speculate that the notch interactions cancel out input signal even more. It’s an interesting effect, often in need of some gain-staging. More subtle, and vaguely vocal-like.
Conversely, lowering the main Depth also reduces the effect of Manual – Depth Mod. After all, it’s the parameter you’re modulating. Esoteric use case, for sure, but potentially useful in your bag-o’-tricks. One more way to tone down an otherwise overpowering effect, by blending Depth & Depth Mod levels to fine-tune Manual Mod travel.
