Home › Forums › Products › Rackmount › H9000: -24dB maximum gain reduction in expression pedal mapping?
December 27, 2019 at 10:41 pm #115680
Why is there a -24dB lower limit on the gain reduction that can be applied to the output of a module? I want to use one expression pedal as a volume master pedal, but with a high headroom guitar amp, -24dB is still very audible, so essentially, I cannot lower the volume to zero. I don’t know if I am doing somehting wrong or else, but this is a problem.
Please let me know.
PH
December 29, 2019 at 6:09 pm #153627J20056 wrote:
Why is there a -24dB lower limit on the gain reduction that can be applied to the output of a module? I want to use one expression pedal as a volume master pedal, but with a high headroom guitar amp, -24dB is still very audible, so essentially, I cannot lower the volume to zero. I don't know if I am doing somehting wrong or else, but this is a problem.
Please let me know.
We intended these controls for level matching and just didn't anticipate this usage of them as volume controls. I can't think of any reason not to extend the range so they go all the way to silence though, and we can add this in a software update.
Please let me know.
PH
well, now you can use your SBGL. I do. :-). Cool that they would add to the H9K though.
January 2, 2020 at 7:21 pm #153655
Indeed.
@eventide: The gain control to -Inf instead of -24dB is no longer a priority for me as I went back to using my SwitchBlade GL which gives me full volume control of each virtual cable. if you have no other need for it, then do not worry about it on my behalf. What I care about the most now is the ability to use Scenes via MIDI PC changes. I’m good on everything else as I am going to loop ADAT to connect FX Chains. Another pet peeve of mine is the inabilty to do direct connections in FX Chains (not in the Direct Connection area). Seems that the only way is to insert a Thru module that consumes 1 out of 4 modules.
