H9000 + Ableton + External Soundcard = USB In/out possible?
Home Forums Products Rackmount H9000 + Ableton + External Soundcard = USB In/out possible?
Viewing 4 reply threads
    • #115111
      ssgrfk
        Hello
        I have a H9000 + RME Audio Interface and ableton / protools
        Im using the H9000 with Ableton via AES / EBU for 1x Stereo Channel. so far so good.
        i was wanting to utilise the H9000’s USB Audio IO capabilities if possible but Disableton Live only permits use of one ‘device’ for Audio IO (as far as i know) so if i select the H9000’s USB IO, i loose the ability to use my RME audio card..
        does anyone know a way around this?
        thank you 🙂
      • #150843
        jbamberg
          ssgrfk wrote:
          Hello
          i was wanting to utilise the H9000's USB Audio IO capabilities if possible but Disableton Live only permits use of one 'device' for Audio IO (as far as i know) so if i select the H9000's USB IO, i loose the ability to use my RME audio card..
          thank you 🙂
          If you are on Mac OS. you can use Audio/MIDI Setup to create an aggregate audio device, and use that in Ableton.  See https://support.apple.com/en-us/HT202000 for details.  On Windows, I don't know of a way to do this.
        • #150847
          ssgrfk
            : ) Thank you! i will do this!
          • #150870
            ssgrfk
              hello.
              ive followed the instructions on the apple website to set this up. Everything appears to be done as per the instructions and i now have the extra channels available in Ableton via my Aggregate device but when i route audio into those channels, being the USB inputs to the H9000, nothing appears in the H9000 on those channels. no audio comes in via the metering. Is there anyone available to help me trouble shoot this or anything that you can suggest?
              thank you
            • #150876
              ssgrfk
                hello
                i solved this by switching to ADAT. i wasnt getting any audio I/O there either but solved it by changing Ableton’s Khz sample output rate to match that of the H9000
                thxx
