H9000 hardware Rev?
Home Forums Products Rackmount H9000 hardware Rev?
    • #115080
      dforman
        I see the latest H9000 firmware update is for hardware Rev g. I bought an earlier H9000 which I suspect doesn’t have the latest hardware Rev. What’s the difference in the hardware, and is it possible to upgrade the hardware to the latest Rev if the changes are significant?
      • #150696
        jbamberg
          dforman wrote:
          I see the latest H9000 firmware update is for hardware Rev g. I bought an earlier H9000 which I suspect doesn't have the latest hardware Rev. What's the difference in the hardware, and is it possible to upgrade the hardware to the latest Rev if the changes are significant?
          Hi dforman,
          You can check the hardware revision of your H9000 in the "info" page in SETUP mode.  Under SYSTEM INFO, it will say "Model: H9000 (Rev G)" or something similar.
          All units that we shipped to customers were either Rev F or Rev G.  The differences between these do not affect the functionality in any way.  The comment on release 1.0.0[41], which says "Update for Rev G hardware", just means that the release added support for the new hardware rev, but it will work equally well on Rev F.
        • #150697
          dforman
            Yes, mine is Rev F. May I ask what was changed in Rev g? Thanks.
            • #150700
              jbamberg
                They are very minor changes that don't affect any aspect of the H9000's functionality.  We had to adopt a newer rev of a programmable logic component that required a resistor value change, and we moved a connector to improve access when technicians are connecting the H9000 to our QC test fixture.
                Revisions prior to F have more significant differences, but in all user-visible aspects, F and G are identical.
