h9000 toggle switch suggestion
Home › Forums › Products › Rackmount › h9000 toggle switch suggestion
    • #115104
      tmoravan
        Let me start by saying I generally love the UI on the H9k.  Very easy to get around, allows me to find and directly edit the parameters I care about; all good.
        I do have a suggestion for the parameters you are representing with a toggle switch (mono/stereo, fast/slow, etc).  Right now, I arrow over to the parameter and turn the data wheel.  Currently a menu pops up and makes me stop and read it and then twist the wheel to select what I want.  that’s kind of slow and distracting.
        Why not have the text under the toggle switch change directly when I turn the data wheel like virtually every other parameter?  That’s seems faster and more in-line with how the rest of the UI operates.  Also allow the up/down arrows on the keypad to change the value too.
        thoughts?
        thanks,
        Tom
      • #150794
        jbamberg
          I do have a suggestion for the parameters you are representing with a toggle switch (mono/stereo, fast/slow, etc).  Right now, I arrow over to the parameter and turn the data wheel.  Currently a menu pops up and makes me stop and read it and then twist the wheel to select what I want.  that's kind of slow and distracting.
          Why not have the text under the toggle switch change directly when I turn the data wheel like virtually every other parameter?  That's seems faster and more in-line with how the rest of the UI operates.  Also allow the up/down arrows on the keypad to change the value too.
          You're right, the toggle switch doesn't need a popup list – we should probably change that.
          However, you can also just toggle the switch by hitting the Enter (check) key instead of using the wheel.
        • #150842
          ssgrfk
            Another UX feature i’d love to see on EMOTE would be the abilit to double click on any fader / rotary knob controller and have that fader / knob etc return to ZERO value or even better, for a knob, cycle through Minimum / Default / Maximum values.
            and perhaps setup some dedicated forum thread for Emote UX feedback / ideas.
            • #150845
              jfirlik
                ssgrfk wrote:
                Another UX feature i'd love to see on EMOTE would be the abilit to double click on any fader / rotary knob controller and have that fader / knob etc return to ZERO value or even better, for a knob, cycle through Minimum / Default / Maximum values.
                If you hold the Alt key on your keyboard while clicking on a parameter, it should snap back to its default value (if it has one defined).  The current version of Emote doesn't implement very many other shortcuts or key commands at the moment, we realize this and welcome any suggestions for ways to speed up the workflow.
