How to change the battery in the Eclipse….
Home Forums Products Rackmount How to change the battery in the Eclipse….
    • #108031
      guitarhaus
      I need to know the proper proceedure in changing the battery in the Eclipse as to eleminate any problems that may appear such as lost of information, programs, or Gliches.  I realize the battery is the BR2330, just wanted everything to run smoothly.  Thanks….
    • #122499
      Strictly speaking, to preserve all the information, you will need to change the battery with the unit powered up. For obvious reasons, this is NOT  RECOMMENDED for anyone but a qualified technician. Either way, it would be at your own risk.
      Probably better to save the setup and user presets to a card (see UM), power the unit down, and reload. Mistakes would be unfortunate.
