How to install the routing utility on Windows XP
Home › Forums › Products › Rackmount › How to install the routing utility on Windows XP
Viewing 3 reply threads
    • #109195
      Hi –
      I tired to install the routing utility on windows XP, but it won't start.  The error message
      says, "This application has failed to start because the application configuration is incorrect."
      Thanks/
    • #123902
        It probably means that you need some Microsoft files that are not included with XP. These are most likely MFC90.DLL and MSVCR90.DLL
        Probably the easiest way to get these is from:
        http://www.microsoft.com/en-us/download/details.aspx?id=5582
      • #123903
        Okay, I can run the routing utility now.  But it refuses to connect to the H8000.  I can connect
        with vsigfile.  I completely quit vsigfile, and then start the routing utility, but it won't connect.
        Thanks,
        Eric
      • #134939
          If you haven't already, check the Comms Config under the system menu. You will certainly need to have every other PC application disconnected from the H8000.
