how upgrade???
Home Forums Products Rackmount how upgrade???
Viewing 11 reply threads
    • #106448
      romadream
      Hi!…i've an Eventide Eclipse powering 3.0 software..
      when i try to upgrade it to 3.5 version, i put the compact flash card into it…..i turn it on holdin' 1 key and a message appears……the eclipse copy only one file and then stop itself….
      what can i do please????
      the bootloader is the 1.2 version.
      Thanx a lot!
      Marco.
    • #119057
      Help us to help you:
      What message ?
      What file copied ?
      What size and type of card ?
      And on and on …. information please !
    • #119060
      romadream
      ok….
      The message is "loding ROMPROG.EXE from card"…….when it's finished the eclipse stop itself.
      I use a SANDISK Ultra II 4 GB Compact Flashcard.
      I don't know what can i do!
      If you need more info tell me please
      M.
    • #130172
      This issue has been covered many times on this Forum.
      You need to reformat the card as FAT (not FAT32) on a PC (not a Mac, sorry), and then copy the files and perform the upgrade again.
      Then it should work.
    • #130174
      romadream
      Ok thanx a lot!……..i'll try and let you know if it works!
      M.
    • #130175
      romadream
      Now it works!!! THANX A LOT!  Smile
      M.
    • #147863
      giorgio71
      Hi there, a bit late on this thread but….here i am
      I’m experiencing exactly the same problems. same version, same message, same file….
      But…As i’m following your suggestion to format in fat (with a pc) and copy all the files in as they are, Eclipse tells me the card isn’t formatted.
      as I re-format the card with the eclipse, pc show me it’s a fat32. I copy the files, power on the eclipse with 1 key pressed, it copies again the romprog.exe and stops…and so on…
      any other suggestion?
      thank you for your help
      Giorgio
    • #147864
      Try with a smaller card (1G or below) formatted as FAT.
      Earlier versions of Eclipse do not support FAT32.
      • #147865
        giorgio71
        hello there.
        unfortnuately It’s already a 1Gb card and, as mentioned, it’s fat, not fat32.
    • #147866
      giorgio71
      sorry, i didn’t mention my card details:
      Lexar Professional
      1Gb 133x
      regards
      Giorgio
      • #147869
        giorgio71 wrote:
        sorry, i didn't mention my card details:
        Lexar Professional
        1Gb 133x
        For obvious reasons, it's very difficult to diagnose these problems remotely.
        I would suggest that you try another (smaller) card, formatted on the Eclipse. If that does not work, send the card to Eventide, marked for my attention.
    • #156272
      eventidesteven
      I am attempting to update and am experiencing the same issue as giorgio71. Any solution. Thanks
    • #156303
      Juan_Maria
      Hi. I have updated Eclipse from version 3.1 to 4.01, going through 3.51 first. I did it with a 128 megabytes Compact Flash card and used an Olympus Cadmedia C-8080 Wide Zoom digital camera to format the card and the subsequent file copies. Everything worked the first time and without problem. Greetings.
    • #156304
      Glad it went well for you.
      Other users should note that in general we recommend that you take an unused card and do not format it before use. (There are various possible formats and one cannot be sure which one is being used).
    • #156281
      Please try a card 512M or below, formatted on the Eclipse, as suggested above.
