April 11, 2012 at 3:19 pm #108607
Rustam
MemberDear Sirs,
I bought Eventide 7600 as second hand. The Seller told that the unit is OK but when I turned it on the unit started to give the error message “faulty presets code installed contact factory” and then nothing happens.
I tried to use the advises from here http://forum.eventide.com/cs/forums/t/4902.aspx
But it did not help.Please help!
April 11, 2012 at 3:58 pm #123304
ModeratorEventide StaffOne further thing you can try is to update it, in case the problem was caused by a failed update. See 7600 support page for more info.
If that fails, it needs to come to us or a dealer for service. Since second-hand units are not normally covered by warranty, you may want to discuss this with your Seller first.
April 11, 2012 at 7:56 pm #123305
Rustam
MemberThank you nickrose,
I tried to register my unit but the site gives the message "Invalid Serial Number".
How can I register my 7600? I can send you the pic of my unit.
And then I would like to try to update the software.
April 11, 2012 at 8:27 pm #134409
ModeratorEventide StaffYou should contact support@eventide.com, giving your full details, and especially, the complete serial number (from the label on the side).
April 13, 2012 at 3:19 pm #134411
Rustam
MemberDear nickrose,
Sent you the pic of my unit 7600 with the serial number and model.
Please help me to register it on your site.
Best,
Rustam
April 13, 2012 at 3:49 pm #134412
ModeratorEventide StaffPlease be so kind as to do as I asked, and contact support@eventide.com with your information. They can help you here – I can't.
