May 13, 2012 at 2:18 am #108737
Could someone advise, what H3000 model will harmonize my vocal to a 8-voice jazz chord played on a connected MIDI keyboard.
Can I get this feature from a plain H3000, or do I need to get the never H3000 D/SE model, or a H3500 outright? I'm trying to find the most affordable Eventide unit with this feature that I can put on a record. TIA
May 15, 2012 at 1:22 am #123433Quote:I'm trying to find the most affordable Eventide unit with this feature that I can put on a record.
Just a thought (after stumbling upon this post). For less than $630 US (an Eventide PitchFactor pedal and an event processor), I can get any four voices. The resulting quality on a vocal input varies from great to adequate (depending on the input and complexity of the the voicings).
Maybe this MIDI translation from MIDI notes to CC values will help out in whatever future purchase you decide on. Here's a diagram of the concept and the original post.
May 23, 2012 at 8:18 am #123462
Hello Brock,
Thank you for the suggestion, it is quite an interesting concept indeed. These days a used H3000 (the original of the series) fetches $500-$600 on Ebay as well. I just missed winning one at $500-ish on April 15th because I overslept
March 6, 2020 at 2:23 am #154233brock wrote:Quote:I'm trying to find the most affordable Eventide unit with this feature that I can put on a record.
Hi Brock. Are you able to play the 4 harmonies in Quadravox on an H9 using your above method? If so, are the notes produced in the pedal the actual Midi Notes being played (like the Meris Hedra for example), or simply intervals in relation to the physically played note on the instrument being used?
