July 29, 2012 at 1:01 am #108979
PedroPower
MemberI've had my H8000FW for about 2 weeks and cannot for the life of me get the ADAT input to work. I used the routing preset ADAT A-B and set the main inputs to ADAT in 1-8. I have checked my ADAT cables work properly and there is definitely a signal being sent to the Eventide.I have set the clock to ADAT.
If I switch Main Inputs to analogue 1 everything works (as I have analogue inputs connected as well) and the input LED lights up. No matter what I do I cannot get the input LED to light up when using ADAT to feed in the audio signal.
Help would be most appreciated!
July 30, 2012 at 3:18 pm #123682
ModeratorEventide StaffThere is a bug in the current shipping version (fixed in beta update 5.6B2 available from our Web Site) that causes the unit not to initially clock to ADAT.
To see if this is the problem, switch the clock source to something else, then switch it back again and see if ADAT shows LOCKED.
Otherwise, make sure that your ADAT connectors are not too bulky – the connectors are quite close and bulky plugs may not be able to push in properly.
July 30, 2012 at 11:21 pm #123688
PedroPower
MemberHi,
Thanks for the reply. I have slim ADAT connectors and they clip in to the ADAT ports on the back on the H8000FW. I can recieve ADAT signals from the Eventide but it doesn't seem to accept them. Like I said, the input LEDs don't light up.
I checked the clock and it says that ADAT is 'unlocked'. I upgraded the production software on the Evenitde but still have the same problem.
Sorry, I'm probably missing something obvious…
July 31, 2012 at 2:37 am #134734
wilkinsi
ParticipantI overlooked the same thing on the Eclipse. Both source and clock must be set correctly.
July 31, 2012 at 8:38 pm #134735
ModeratorEventide StaffIf the clock is set to ADAT and it shows unlocked, assuming you have checked for the bug I mentioned earlier, you either have a bad source, or a bad cable or a bad H8000.
Double check your connections – this is the most likely issue. Make sure that you can see red at the end of the ADAT cable.
You can do a simple check of the H8000 by setting it to 48k internal clock and connecting the "ADAT in" to the "ADAT out" – it should then show "ADAT locked". If not, contact support@eventide.com
August 1, 2012 at 1:52 am #134736
PedroPower
MemberThanks heaps Nick. I have sorted it out, it was my stupidity. Thanks for your help. Onwards and upwards!!!
August 1, 2012 at 1:52 am #134737
PedroPower
MemberYeah, woops. Thanks for helping!
