No continuous levels on new H8000FW
Home › Forums › Products › Rackmount › No continuous levels on new H8000FW
Viewing 4 reply threads
    • #107689
      zap
        So the unit was working for a while, and then as soon as I went into the criteria for sorting, there was no more sound.  Went back to routings to analog and Spd-f – and then just brief spurts of a test tone and then nothing sounds.
      • #121672
          It's almost certainly a routing or gain issue. Try some the factory routings and see what happens.
          If you think it is a hardware problem, contact support@eventide.,com
        • #121676
          zap
            oh thats ok, i figured something out…. this was just at the beginning so that you know when people first get something they just want to delve through all the sounds before reading the manual.
            the other thing is, the unit gets hot pretty fast.   is this normal?  My axe fx does not get that hot, only a bit warm after an hour of use.
            i am just wondering, i hope i will be able to use this as stereo and not just 5.1.   Just to make it act like a couple of 7600s for whem my guitar goes in mono and can come out to converted stereo for FX… and same for the vocalist.   Is this possible?  (Yes I know I have to read the manual but I am just asking for now).   And also – is the tap function possible to be "per preset" rather than global?
            thanks
          • #132900
              You do have to read the manual, but you know this …
              H8000's run hot because they have a lot of stuff in them, and audio gear doesn't have noisy fans. Sorry.
              Depending on the presets and the routing, you can run the H8000 as multiple stereo effects. For example, there are single presets with 4 stereo reverbs, and you can run two at a time.  But, many of the effects are stereo or multiuchannel (e.g. 5.1).
              Once you get experienced with Vsig, you can often combine smaller effects to give a wide range of combinations.
            • #132905
              zap
                Ok, well a more severe issue (aside from the fatal reboot errors)  at this point is that the Tempo does not save with the preset.  I modded my presets to sound exactly like I want to a tempo i want and the tempos did not save.
                What good are such amazing FX if the utility in this machine is not flexible?  In my axe FX I can choose whethr I want the tempo to be "per preset" or  "global".
                If I switch to a certain preset live that is at a wrong global tempo – this will be somewhat unpleasing to spectators.
                In addition, on some effects – a tempo change simply has no effect.  so if I want to have a custom sequencer coming in (either the one I am hiring somebody for – or an external one sending incoming CC data) , on the effects which are based on numerical cycles rather than relative rhythmical ones, is there more of an intuitive way to make the cycle ones fixed to rhythmical resolutions?  Because my incoming sequencer cannot be that intelligent to know which portion of the cycle to stop at so that its rhythmic… same if I use a pedal – to – rate that is not rhythmically-based resolution.
                I will stop there assuming you know what I am talking about.
