No Forced Feedback for presets 850 & Co
Home Forums Products Rackmount No Forced Feedback for presets 850 & Co
    • #108141
      I wanted to use forced feedback for presets 850 & co of my Eclipse v4.01 but this parameter is not present in the hotkeys list for these presets: it only displays "output level" and then "sweepable Mid EQ" (and also classical hotkeys like drive, bass, mid, treble).
      Is this normal ? Did you have same issue ? Where can i find this "Forced Feedback" hotkey, and how to parameter it with an expression pedal (I have a Roland  EV-5 which works fine with other presets) ?
      Many thanks in advance for your help.
    • #122742
      I'm not familiar with that preset, but if you can find the desired parameter in the parameter pages you can easily link it to the hotkeys by holding down its button.
    • #122855
      It is in the parameters, a few levels down.  Easy enough to assign it to a hotkey in the usual way.
      But when you link it to an external (e.g. pedal), don't use ext5 and above as these are pre-assigned to work with an Eventide stomp box.
