August 24, 2012 at 2:15 pm #109048
Hi all,
I recently got a second hand DSP7000 – brilliant!
just one question… whenever I turn it on the output levels are set at -90db (always!) and each time I have to remember to go to the levels page and set them back to 0db or I don't get any sound..!
Is there any way I can save my setup 'on exit', as it were, so that it powers up with the settings (ie. output levels) the way I left them?
nice one!
cheers, steve.
August 24, 2012 at 2:58 pm #123757
Glad you like it ! The levels should be saved automatically. It is possible that the internal battery is gone, although you would probably have other issues were this the case. First thing to try ..
August 25, 2012 at 9:18 pm #123759
thanks Nick – good point.. but i'm not experiencing any other anomalies (well, not that i know of – i'm not exactly a 'power user' just yet!) – what other signs would there be if the internal battery was dead (or on it's way out)?
cheers.
August 26, 2012 at 2:52 pm #134797
If the battery was failing you'd be getting at the minimum "checksum" errors, and general problems with saved programs and settings.
August 27, 2012 at 5:28 pm #134803
Thanks again for your help Nick, I'm afraid I'm not sure what a checksum error is..
, but the unit DOES save my 'bank' where I've collected my fave presets – I'd imagine that would disappear if the battery wasn't working, right?Steve.
August 27, 2012 at 5:45 pm #134804
If you have checksum issues, you'll get a warning message telling you. So, if you don't see it you're OK.
August 27, 2012 at 6:09 pm #134805
Yay! I just read in the manual about 'clear setup', to return to factory defaults.
Done.
Problem solved!!
Thanks again for your kind attention Nick.
All the best,
Steve
